help please ..my son has a thomson speedsearch 330 modem and it needs to be uninstalled then reinstalled but he has lost the modem disc , does anyone please know if it is possible to download one . thankyou in advance
Hopefully you mean a Thomson SpeedTouch 330 modem, then you can download the software here:
http://www.speedtouch.co.uk/330.asp
Although you might want to check your ISP's site first, in case they have an ISP specific set up disk.
STOP POSTING WHILE IM POSTING!!
hey there.
i found some but i just need to know what OS hes running.
ex. XP, 98, 95, ect..
and if its XP, is it 64 bit?
the website is found here, http://www.speedtouchdsl.com/support.htm
by the way, its speedtouch.
hey there.
thankyou for your help
just make sure its the modem that plugs in using USB.
any questions, just let us know.
glad to help.
If it connects via USB you need drivers. If it connects via Ethernet cable it needs no drivers.
if it connects via fat women, you need alcohol, and lots of it.
