To start things off im trying to reover my music and videos off of my ipod. i know this can be done because ive done it before. the thing is ive never had this specific problem. it appears as though the ipod is completely non accessible. when i plug it in it says i have to reformat it blah blah. well thats the reason i downloaded this program. anyway when i go to select the ipod in recuva it starts to scan but then says "The Parameter is Incorrect". any help is greatly appreciated.
edit: i just thought of something. if i was to reformat the ipod, would recuva still be able to find my files?
Possible but I think it would depend on how many passes you do. A low-level format might allow you to recover them. Something like a DOD or NSA rated format would probably not yield good results for recovery of your files.
so if i used the itunes restore on it you think i would be able to recover my music still? idk its kinda just a shot in the dark and it seems like thats what im gonna have to do anyway cause nothing is letting me look into my ipod.
