Temperature Indicators
Just installed Speccy and have a question. At what temperature does the indicator change from yellow to red? I have only seen these two colors, are there others? Are these values specifically related to the hardware it is monitoring, i.e. AMD Athlon processor?
They'll all be green if they fall within the sensors' safe parameters. I'm guessing you are running a laptop that needs a good internal cleaning.
