Temp Folder Cleaning
Hi guys :rolleyes:
Just wondering if it's necessary to let windows keep the contents of Temp Folders for 48 hour's?, is this just a safeguard?
Hi guys :rolleyes:
Well years ago it used to be keep all the junk for 7 days, then some started going the 2 day ("48 hour route"). Personally I just get rid of it right away.
A safeguard yes, but only if installing and uninstalling software that requires the usage of the temp folder after a reboot. However if any other software is storing important or needed files in the temp folder it's just plain stupid programming.
I have had the option "unchecked" for about 6 cleaning sessions with "CCleaner" and have had no problems B)
