System Uptime
Would it be possible to add a "System Uptime:" under Operating System?
Thanks!
System Uptime needs to be calculated in Real-time whereas Speccy updates at the very start (AFAIK), you can see the Up time in the Ctrl + Shift + Esc... > performance tab if you really want to.
EDIT: I'm not saying it shouldn't be added.
