hi
something i have not been able to find is a utility that will allow you to save the actual system restore folder/files of restore point that you want to keep in vista. Vista deletes old restore points without asking if you want them deleted. So even the ability to have windows ask permission to delete a restore point would be a partial solution. Many times i have wanted to be able to go back to the very first restore point made. Would be great to see this option implemented in CCleaner.
