System Protect
"We are proud to announce the release of our brand new security product
System Protect.
Information about the product can be found at here
Have you ever been infected by viruses or malware and had to go through
an arduous process of restoring critical system files?
Have you ever used an antispyware program which has falsely identified
and deleted Internet Explorer favorites or important programs?
Have you ever used hard drive cleaning applications only to find that
important documents, pictures or other desired files have been deleted?
Do you share a computer with children and worry that they will delete
important documents or system files? Do you worry that you might do the
same?
If you have ever asked any of these questions, then System Protect is
for you. Right out of the box, System Protect will actively protect the
integrity of critical system files. With a few extra settings, you can
also use it to protect important documents, pictures, music, favorites,
and any other file you never want to lose! It provides the protection
which no other security program can provide, for FREE!
Currently System Protect is in beta stages and we'd appreciate it if you
could test it and give us your feedback. We hope to release a finalized
version of System Protect in Q1 2008.
We would like to ask you to install the application, check its functions
and send us any bugs, comments or suggestions by posting in the new
forum created for System Protect here:
http://forum.spywareterminator.com/Default...topics&f=60
The application can be downloaded at http://www.system-protect.com/
From http://forum.spywareterminator.com/Default...osts&t=3601
Basically a file/folder guard from the guys at spyware terminator? Description seems similar to drivesentry?
I have not tried this yet nor am i recommending it. It is also BETA.
Lusher
I'll try it on my WinXP Home system that I just finished installing the Service Pack 3 RC1 upon.
Does that program run in the background?
Yes.
I don't like it :angry:
It prevents running Disk Cleanup that I think is necessary to clean out the Compacted files before a Defrag after a major download and install of a Service pack to keep the hard drive running at peak efficiency.
What kind of question is that? Even spyware blaster's protection doesn't come free.
Hmm how often do you install a service pack?
Um, disk cleanup doesn't 'clean out' compressed files, it compresses files that haven't been accessed for a certain length of time. This is generally a bad idea - they don't get uncompressed when they get accessed again so you can end up with a large amount of compressed files on your disk and these files will have slower disk read times. Unless you are nearly out of disk space there's no reason to do it, even then there are better ideas than compression.
Can be configured to "ask" rather than the recommended "block and inform".
This should prevent any problems when using a cleanup utility.
Information regarding which files, or series of files are protected (apart from those you define yourself) is rather scanty, so far.
I can't change Internet Options now :angry:
How do I fix this :blink:
How can I prevent this?
This system is starting to slow down to the speed of molasses at the North Pole :angry:
YoKenny, try undoing stuff in the reverse order you did it. (As indicated above, you can't undo compress old files,) but you can uninstall System protect. Do it, and see if that makes a difference.
Must say, you're fairly brave running the SP3 release. It's fairly young. Did you save the service pack to disk? I ask in case you have to do a full reinstall of Windows. If you did save it, you could reinstall Windows, then install the SP. That's a way of "un-compressing" the old files. Hopefully someone might know a better way.
I did that and ran RegSeeker then NTREGOPT then did a reboot and it made no difference.
Its my test system and I don't do anything on it before I run it for about a week before updating my WinXP Pro system.
I think I'll do that as a FORMAT then reinstall always amazes me at how fast the four year old 2.4GHZ P4 becomes. ;)
The system has an 80GB hard drive partitioned into two 40GB drives and I keep all the important stuff on the second partition.
I have a SP2 CD from Microsoft that I'll install but there probably will still be over 60 Updates to install.
I have nothing better to do as it is windy and cold here and Santa will be real busy for the next few hours so I'll warm this place up with some computing power.
I won't be installing the SP3 RC1 software and I'll wait until SP3 becomes GA.
