Hi,
In the top of the main window, is the description of the system, for example:
Windows 7 Home Premium 64-bit SP1
Intel Core i7-4700 CPU @ 2.4GHz, 8,0GB RAM, Intel Graphics 6000.
My suggestion is about de RAM value, this is 8,0GB instead 8.0GB. I think is better with point instead coma, right?
Thanks & regards.
Nergal
2
Comma is European method; Point is American. Both mean the same
trium
3
i mean too.
on my ccleaner is there a point :-)
(w8.1 64)
maybe a windows 7-category problem in ccleaner?
mta
4
it would depend on what Region/Location you have Windows set to.
