synaptics pointing device
after running ccleaner 4.10 for the first time, the settings of my laptop's touchpad reset to default settings. thanks.
that was poor sentencing. it made me sound like i was being sarcastic when i added the thanks at the end. i meant to say thanks for any future help.
Windows version? Did you run registry cleaner?
windows 8.1 64-bit. yes.
Did you make a backup of the registry entries when offered the chance to do so?
no, i didn't. never done that since ccleaner was always reliable prior to this problem.
Always back up the registry entries when you use the reg cleaner :) (that's if you even think you need to run the reg cleaner)
Perhaps you could analyse with the reg cleaner, see what the setting is it wants to delete, then exclude it.
ah, alright then. thanks for the help. i do hope piriform would still look into this.
