Superantispyware 3.5 And CCleaner Needs Updating.
SAS has recently released an update to 3.5. The winapp2.ini for SAS is no longer working. That is because the logs for SAS are now kept in C/Documents and Settings/user name/application data/SAS/logs folder. As you can see with this winapp2.ini entry they used to be kept in the C/programs/ SAS/ Logs.
[sUPERAntiSpyware (Logs)]
LangSecRef=3024
Detect=HKLM\Software\SUPERAntiSpyware.com\SUPERAntiSpyware
Default=True
FileKey1=%ProgramFiles%\SUPERAntiSpyware\Logs|*.log
I got SUPERAntiSpyware and didn't even notice that. I will be releasing a new update sometime tonight, it will be fixed.
Thank You :D
This actually takes care of the new SAS version:
Edit: Screw it, the forum is messing up the quote and the code.
I am quoting
I am making a codebox
Duh, yeah that works. :rolleyes:
What I was talking about was when posting the actual cleaning routine it was bunching the LangSecRef up next to the entry name, there wasn't anything I could do to fix it.
I was making sure, the Forums have been really screwed up lately.
Whats the latest with this? :)
Well, everything didn't go as planned. I was going to add several new entries to the winapp2.ini and release it, but... Well, I can't explain it, just yet. :)
I am going to release it today, it will be a small update with only a few entries.
