Stuck updating
Trying to install updated Speccy on my Win 10 PC enterprise edition Minisforum I5-11320H CPU 16GB RAM but it is stuck extracting speccy.exe the progress bar is about 50 percent then it just sits there doing nothing for days.
Useless forum - no replies received! Time to uninstall Speccy.
This is a user forum so you won't get help unless a user can identfy the issue.
Maybe you're blocking server access in your firewall?
On 18/10/2022 at 04:01, vaughan said:
Where did you get the installer from?
https://www.ccleaner.com/speccy/download
or
https://www.ccleaner.com/speccy/builds
Please note the last update does not bring any additional functionality
Release notes
Speccy v1.32.803 (14 Jun 2022)</em>
We're pleased to announce that the latest version of Speccy has had a small update. This change introduces some improvements to Speccy’s integration with our licensing platforms. This groundwork will allow us to work on changes that will provide a smoother license delivery experience in future.
From the first URL you typed. Doesn't matter as I uninstalled and gave up on that machine. I have fully licensed versions on other machines that work fine.
