stuck at 72%
my ccleaner keeps getting stuck at 72%
i have left it there for quite a while to see if it will advance but it just doesn't seem to want to do that.
i don't know why or how to get it to clean out the last few sections.
does anyone know if there is anything i can do to help this along. it worked do soooo good up untill that point!
Can you see what section it is getting stuck on?
	If you are using Easy Clean/Health Check then the section it's stuck on should be show underneath '# Trackers' and/or '#MB of Junk'.
	If you are using Custom Clean it should be shown at the top of the results window.
