Trying to recover files from a completely different Harddrive.
tried using chkdsk f but no avail since it didnt allow me to do so. saying no direct access to the drive..\
tried changing drive letter but didnt work either.
then i stumbled an article saying that probably main issue is that the drive partition is broken/corrupted
its actually set in Raw at this point.
using recuva allows me to gain insight that all the files are still intact.. since i had to stop scanning and see if there is actually a chance of recovery..
did a quick rescan and stuck at 44% .
repeat a quick scan and stuck again at 44% same number..
i only want to recover files that is currently available on the drive without the need of scanning the deleted files..
trying to recover 300gb+ of files only
