Still NOT WORKING
Hello Me again,
Ok I un-installed and re-installed downloaded XP sp2 followed the link and downloaded the VB6 pack STILL NOTHING HAPPENS WHEN I TRY TO OPEN OR RUN CLEANER!!!!!!
There is a lot of good things said about this cleaner I would like to find out if it is true.
Why is it not working for me.NEED HELP
After installing the Microsoft VB6 Runtime restart your computer, do the same after you install CCleaner. For some reason even on XP machines a reboot is still needed in order for some installations to start working.
