Found the following two programs listed under my Startup / ScheduledTasks CC Cleaner tab and don't know what they are or what I should do - keep enabled or disabled or delete?
IHSelfDeleteTASK
IHUninstallTrackingTASK
Do you require the rest of the information on these lines to anwer my query?
Thank you so much!
YB
You don't need to create multiple threads for the same question/problem. Also not sure if "Bug Reporting" is the right category for this.
Those are probably safe to disable. If no problems occurs during boot/restart, you can delete the tasks.
Which Windows & CCleaner version are you using?
Edit: The 2nd thread got removed.
Edit2: Spammer? You created at least 4 threads considering this..
Yes, what are you up to? Five identical topics is just too much......
