Start > Run is not cleared
Hello,
I'm using the latest 2.27.1070 CCleaner. It seems like when I leave all settings at default (just after installing), the string(s) entered in Start > Run dialog are not being cleared.
I don't recall this happening in previous versions.
XP Pro SP3 32bit
Hi,
You'll need to reboot before the run command box is cleared in XP.
When CCleaner is run in Vista, the box is cleared immediately.
