Normally when I require a custom clean the recommended boxes are checked automatically.
I have accidentally unchecked all boxes for the Custom Clean option.
How do I restore the standard items. I use Chrome and Edge.
You have a couple of options:
If you want to reset all of your settings everywhere in CCleaner then go to Options>Advanced and at the bottom of the list you'll see 'Restore Default Settings'.
If you just want to reset the ticks/unticks in Custom Clean then right-click on the Windows or Applications tabs in Custom Clean.
That gives you the option to 'Restore Default State' for the ticks:
Thanks that did it. Shame it had to be buried so deep!
