Spyware Blaster Problem
One of my favorite security programs is getting terminated whenever I click on enable all protection.
An error message comes up saying: Error: Access violation at 0x005F71FC (tried to read from 0x067B038C), program terminated.
I've never had this problem before and I've tried reinstalling. Please help, I can't do without Spyware Blasters protection! :(
What fav security program? You need to state what it is in order to get proper help.
Also submitting a support request to both programs developers may make for a quick solution, as in bugfixing a conflict.
Spyware blaster is the program, and I've had the same problem. Tried uninstalling and reinstalling with no luck. I presumed it was a Vista problem. I've uninstalled and will try the program again after the next update.
Its SpywareBlaster but it has not been Vista certified yet.
http://www.javacoolsoftware.com/spywareblaster.html
Hi Icedrake,
If you have Firefox+Spyware Blaster+Spybot and punycode problems (takes all 4) then look here.
http://www.wilderssecurity.com/showthread.php?t=206415
http://forums.cnet.com/5208-6132_102-0.htm...ssageID=2753030
:) davey
You gotta watch out and be sure you got your punycode correct. Sounds like a virus to me.
More information on punycode, for anyone who's curious: http://en.wikipedia.org/wiki/Punycode
I guess that includes us IE7 users also? Naagh!!!
See the above reply.
:) davey
Thanks for the help, everyone! I got my Spyware Blaster working again by unimmunizing Spybot and then enabling Spyware Blaster and then immunizing Spybot again. :)
