SpeedFan setting
I have difficulty in setting of fan system temperature. any help appreciated ?
Look at the following attachment,
My fan system temp is 127C, am I in trouble or is it normal ?
thank you
That seems pretty hot, but you could check it out against HDTune (Free) to see if you come up with the same reading.
Better call the fire department. If it was less than that hot you could kiss your computer goodbye.
There is probably no temperature probe connected to the motherboard for that reading. Often there is a few unused connections for future upgrades or from a previous computer model. When there is they either read extremely cold or extremely hot. 127C is probably the maximum temperature your motherboard can detect. Not that it needs to as anything that temperature would melt/burn. :D
EDIT: I noticed a reading of -1C for an auxiliary probe. There is no probe connected here either. -1C must be the minimum for your mobo. Not that it needs it.
I'll try it, Tom. :) thanks
free version has limited functions but anyway my HD error free.
For aux, sometimes occurred between 0C and -1C, any idea ? :unsure:
I added the side fan to blow in that is connected to sys fan connector on the motherboard but SF didn't read either RPM and temperature :huh: whether it is possible the connector is damaged or not functioning :unsure:
it seems the sys fan doesn't work.
Does the sys fan work?
127 is the maximal value of a signed byte. So I think it's not the actual temperature...
I don't know where it is plugged, I just saw unused sys fan connector/port so I plugged side fan connector on it.
I think so.
