Since I have update Speccy to Version 1.19.411 the GPU dont't display the temperature.
Before this version all the others displayed the GPU temperature.
Hi, welcome to the forums!
Could you provide your:
Operation System (32 or 64 bit as well)
and
Graphics Card
please?
This will help the developers help you, and may help the forum volunteers help you as well.
I went back to V1.18.379 until they fix the bug.
I'm also having the same problem! I've also moved back to 1.18, for win 7 I have not checked to see if it works Win XP Pro.(dual boot system)
Update: 1.19 has the same problem with Win XP pro SP3 with a twist. In windows 7 I just reinstalled 1.18 with out any problems. Under XP pro. Speccy 1.18, under graphic it would show in orange letters (this service is marked for deletion). I had to uninstall 1.18 restart computer, boot into XP then install 1.18, problem solved.
Edit: Still having the same problem with 1.20, had to reinstall 1.18 to get the GPU temps back. As for the later problem I report with XP (see above) that didn't happen this time.
System specs:
GA-MA-790X-UD4P AMD Phenom II 555 BE @3.2 unlocked to 4 cores
Corsair H50 (CPU Cooler)
PS Antec EW 750 / Case Antec 900 II
Asus EAH5770 CUcore
Super Talent 8GB DDR2 6400
LG HL-DT-ST DVD/CD Burner
Hitachi 250 ,WD 250 /Creative SB Titanium X-Fi.
OS Windows XP 32 Windows 7 64 Ultimate.
Been having this problem for months.
Specs:
3570k
EVGA GTX 670 FTW
8GB RAM
Windows 8 Pro 64-bit (this also happened on Windows 7 64-bit)
Same problem. Everything working fine except no GPU temp displayed.
Zotac GTX 660
I7-3770K
8 GB DDR3
Windows 7 Ult 64 bit
