Speccy Pro v1.32.803 (64-bit) throws Program Compatibility Assistant error window for driver cpuz149_x64.sys
Launching Speccy Pro on my MS Surface Laptop Studio 2 running Windows 11 Pro (x64) Version 25H2 Build 26200.7623, opens the error window per the below image. I did some research and found that the Windows Security Memory Integrity feature regards this driver version as an outdated security risk. I don’t want to disable Memory Integrity as that exposes the Windows Kernel. The current version of this driver from CPUID is v2.18.0. I installed the CPUID utility CPU-Z that uses the current driver. I can open and run CPU-Z without Win11 Pro throwing an error. If you’re not planning to soon release a Speccy update with a Win11 Pro safe version of the cpuz driver, can you tell me how I can manually update the Speccy copy of cpuz149_x64.sys to the current version of the driver? Thanks.
Speccy is quite old and has not been updated in generations (before 1TB drives were common).
The developers keep saying it willl be updated but it has been a long time and hardware has changed greatly.
