In SPECCY under OPERATING SYSTEM a value is displayed as SERIAL NUMBER.
That value does not match the value displayed when I issue the command :
wmie path SoftwareLicencingServices get OA3xOriginalProductKey
in the command window.
Shouldn't they match?
Which of those two numbers should I use when I try to do a clean W11 install on a new disk drive?
Thanks,
Walt
If your machine is already activated then you have a digital licence which is stored on the Microsoft cloud servers.
When you clean install from the same machine the licence will automatically be activated.
16 hours ago, hazelnut said:
I am working on a friend's computer and don't have access to her MS account.
I would really like to know why there is a discrepancy between the two reported number. Where does Speccy get its number from?
7 hours ago, kokopeli said:
You do not need to have access to her account. When the machine goes online it get activated automatically by the cloud if the machine has a digital licence
