Speccy not reporting correct memory speed?
Hi,
I have ran speccy in order to query the performance of a new Tier 1 lappy. Running VMware workstation seems slower than on my old machine so wanted to check out why. Had a look at the memory of the device, Core 2 4Gb (800mhz according to the book) and Speccy reports 533Mhz FSB ram running at 399Mhz. However, the manufacturer is insisting the memory is actually 800mhz and questions the Speccy software accuracy. They have tested another,faster machine with Speccy and suggest on a more advanced machine with a Core i3 and 4GB of memory at 1066Mhz Speccy is stating that it is a 533Mhz unit.
i n
Would appreciate some advice as the supplier have been great but I need to know if the s/w is accurate.
I may be wrong, but speccy shows my 800mhz (ddr2 pc-6400) as 401mhz as well, so what I think is that because DDR2 has a double data rate, it might have something to do with that.
i'm using DDR3 1600mhz, and Speccy report me 802mhz. Maybe the programmers will do some fix about this problem someday.
Can you post some .speccy files so we can have a look at these in more detail?
Hello~
I may have a similar problem but not really sure. I just purchased pc2-4200 (533) and speccy is reporting it as being pc2-6400 (800).
Generated by Piriform Speccy v1.07.205
31 Dec 2010 @ 14:41Summary
Operating System
MS Windows Vista Home Premium 32-bit SP2
CPU
Intel Core Duo T2250 @ 1.73GHz
Yonah 65nm Technology
Cores:2
Threads:2
Name:Intel Core Duo T2250
Code Name:Yonah
Package:Socket 479 mPGA
Technology:65nm
Specification:Genuine Intel(R) CPU T2250 @ 1.73GHz
Family:6
Extended Family:6
Model:E
Extended Model:E
Stepping:8
Revision:C0
Instructions:MMX, SSE, SSE2, SSE3
Bus Speed:133.0 MHz
Rated Bus Speed:532.1 MHz
Stock Core Speed:1733 MHz
Stock Bus Speed:133 MHz
Average Temperature:94 ?F
Caches
L1 Data Cache Size:2 x 32 KBytes
L1 Instructions Cache Size:2 x 32 KBytes
L2 Unified Cache Size:2048 KBytes
Core 0
Core Speed:1729.0MHz
Multiplier: x 13.0
Bus Speed:133.0 MHz
Temperature:94 ?F
Thread 1
APIC ID: 0
Core 1
Core Speed:1729.0 MHz
Multiplier: x 13.0
Bus Speed:133.0 MHz
Temperature:94 ?F
Thread 1
APIC ID: 1
RAM
3.0GB Dual-Channel DDR2 @ 266 MHz (4-4-4-12)
RAM
Memory slots
Total memory slots:2
Used memory slots:2
Free memory slots:0
Memory Type:DDR2
Channels #:Dual
DRAM Frequency:266.1 MHz
CAS# Latency (CL):4 clocks
RAS# to CAS# Delay (tRCD):4 clocks
RAS# Precharge (tRP):4 clocks
Cycle Time (tRAS):12 clocks
Bank Cycle Time (tRC):16 clocks
SPD
Number Of SPD Modules:2
Slot #1
Type:DDR2
Manufacturer:ElpidaMax
Bandwidth:PC2-6400(400 MHz)
Part Number:EBE21UE8AFSA-8G-F
Serial Number:5AF61A02
Week/year: 10 / 10
SPD Ext.:EPP
JEDEC #3
Frequency:400.0 MHz
CAS# Latency:6.0
RAS# To CAS#:6
RAS# Precharge:6
tRAS:18
tRC:24
Voltage:1.800V
JEDEC #2
Frequency:333.3 MHz
CAS# Latency:5.0
RAS# To CAS#:6
RAS# Precharge:6
tRAS:16
tRC:21
Voltage:1.800V
JEDEC #1
Frequency:266.7 MHz
CAS# Latency:4.0
RAS# To CAS#:4
RAS# Precharge:4
tRAS:12
tRC:16
Voltage:1.800V
Slot #2
Type:DDR2
Manufacturer:Samsung
Max Bandwidth:PC2-4300(266 MHz)
Part Number:M4 70T2953CZ3-CD5
Serial Number:F5232680
Week/year: 21 / 06
SPD Ext.:EPP
JEDEC #3
Frequency:266.7 MHz
CAS# Latency:5.0
RAS# To CAS#:4
RAS# Precharge:4
tRAS:11
tRC:15
Voltage:1.800V
JEDEC #2
Frequency:266.7 MHz
CAS# Latency:4.0
RAS# To CAS#:4
RAS# Precharge:4
tRAS:11
tRC:15
Voltage:1.800V
JEDEC #1
Frequency:200.0 MHz
CAS# Latency:3.0
RAS# To CAS#:3
RAS# Precharge:3
tRAS:8 tRC:11
Voltage:1.800V
Still, I think in slot#2 speccy reported it as pc2-4300 when I believe the sticker on the ram chip read
pc2-4200.
The pc2-6400 reported by speccy may or may not be pc2-6400. I just bought this and maybe they tagged it wrong@pc2-4200 at the factory.
PP
This isn't a problem at all - read how DDR memory works here: http://en.wikipedia.org/wiki/DDR2_SDRAM
Hello, CPU Temp is not being displayed and RAM speed is showing 400 Mhz although I'm using 800 Mhz sti9cks. See attached clip. Thanks for this great tool I'm counting on it for up to date system info.
Speccy reports 800 on a dual channel 1600 and 400 on a dual channel 800. Thats because there is 400 to each channel for 800mghz, and aprox. 800 per channnel for 1600mghz. That particular specification is per channel. Read the link above to see how Double data rate works.
I have DDR3 1600mhz 8gb (4gb HyperX Blu and 4gb Corsair? Valueram)
Speccy shows 439mhz
and if you try Speccy with just one of those chips at a time, does it show 800MHz each time?
My Speccy part of Pro v1.33.075 (64bit)
DDR4 Ram is running at 3200 MHz not 1596MHz
TASK MANAGER:
Memory
32.0 GB
Speed:	3200 MT/s
Slots used:	2 of 4
Form factor:	DIMM
	Operating System
		Windows 11 Pro 64-bit
	CPU
		AMD Ryzen 7 5700X	72 °C
		Vermeer 7nm Technology
	RAM
		32.0GB Dual-Channel DDR4 @ 1596MHz (16-20-20-38)
	Motherboard
		Gigabyte Technology Co., Ltd. B550M GAMING X WIFI6 (AM4)	38 °C
	Graphics
		ED270 X (1920x1080@240Hz)
		4091MB NVIDIA GeForce RTX 4060 (MSI)	44 °C
	Storage
		931GB KINGSTON SNV2S1000G (SATA-2 (SSD))
		931GB Samsung SSD 870 QVO 1TB (SATA (SSD))	32 °C
		465GB Samsung SSD 860 EVO 500GB (SATA (SSD))	34 °C
		3725GB Western Digital WD My Book 1230 USB Device (USB )
		3726GB Western Digital WD My Book 25ED USB Device (USB (SATA) (SSD))	26 °C
	Optical Drives
		HL-DT-ST DVD+-RW GU90N USB Device
		WD Virtual CD 1230 USB Device
	Audio
		NVIDIA High Definition Audio
