Speccy not launching to try
Hello Everyone -
I've been using Speccy for quite some time. I like to use it to monitor my system temps and other items. I recently re-installed Windows with the Fall Creators Update. Generally, when there is a major update for Windows, I like to do a full re-install.
Previously, when I had it running it would launch to the tray without an issue. I disable the UAC prompt as I found it annoying to have that popping up every time I turned my computer on.
After I reloaded Windows, one of the first items I installed was Speccy. Whenever my computer turns on, even though I have the correct options checked, Speccy launches in it's normal window. I have checked and re-checked my settings and as far as I know everything is setup correctly, and as near as I can tell, there have been no recent updates to Speccy that would have introduced a bug that would affect how this feature works.
Has anyone had this issue, and if so, do you have any tips on how to fix it? I am currently running Speccy version 1.31.732
Thank you!
Nevermind! I got it working. Apparently, you need to let the UAC prompts run a couple of times. I re-enabled UAC, restarted twice and then disabled the UAC prompt for Speccy, and now all is good.
