Speccy No Longer Showing In System Tray
version 1.32.803 64-bit - the free version.
It used to show in the system tray on Windows 10 , but it won't now.
I set all these options in "View/Options/System Tray":
* Minimise to tray
* Display metrics in tray tooltip
- but it doesn't appear in the tray.
It used to work, for years. But now it has stopped.
Presumably you also have 'Run Speccy in tray when the computer starts' ticked?
Has it been shunted into the tray overflow (the up arrow)?
