Hi Derek.
hazel came across this back in July, which you wouldn't have known about of course.
I'll post the link to add those comments to your topic, and yes, lots of us have used SorceForge for years.
http://forum.pirifor...showtopic=39072
Very sad that they're going down the "bundled installers" road, but as long as they're upfront about what an installer contains, and there is an "out" option clearly visible, then they haven't quite descended to the bottom. Yet.
Does anyone on the forum use SourceForge for Windows based software, and if so, had any problems with their software after installing it?
I use several things off there such as Firefox Portable, etc. To get around their adware someone mentioned going to the downloads \file\ folder to get the .zip, .7z, .rar, etc., alternative non-installer to some of the software on there.
Off Topic:
Derek891, why are all of your posts indented? It's peculiar!
Thanks, Derek. I had seen it, but reminders are an important part of my life these days.
