Some questions about Winapp2.ini
Today when I used the Winapp2.ini rule, I tried to write a rule to clean up some folders, but I found that CCleaner's analysis list does not show empty folders.
E.g:
[Test rules *]
LangSecRef = 3021
DetectFile =%USERPROFILE%\Desktop
Default = True
FileKey1 =%USERPROFILE%\Desktop|temp*|REMOVESELF
Folder structure:
%USERPROFILE%\Desktop\test\temp1
%USERPROFILE%\Desktop\test\temp2
%USERPROFILE%\Desktop\test\temp3
%USERPROFILE%\Desktop\test\temp4
%USERPROFILE%\Desktop\test\temp ...
"TempX" are all folders
When I click the Analyze button, the result of the analysis is empty, but the folder can be cleaned up successfully.
Please show empty folders in the analysis results
How is it supposed to show you something if nothing exists? Well in theory.
It's completely different if it's however mapped to a folder location that is static and isn't always changing which has a file in it that always gets created such as:
If it was told to look in "%UserProfile%\Desktop\Temp1" for the file "ScannedImage-1.jpg" (assuming your scanner always created such an image) then it would having something to display.
