some errors after defragmentation
hello!
i did a defragmentation yesterday which was completed without any errors, i didnt reboot my PC that day and everything worked fine, however today on startup, before loading win7 CHKDSK checked my HDD and found a lot of errors and repaired it. After that, win starts up nicely, but some of my programs doesn’t work now becouse some of my DLLs are missing (for example: war thunder doesnt find dbghelp.dll now). Actualy this is the only error i encountered so far but it’s quite disturbing.
is there a way to recover the missing files, is it coused by defraggler or i did something wrong?
thanks in advance!
did you run anything else apart from Defraggler?, like CCleaner?
I ask because DF only 'moves' things around, it doesn't delete things except for the Recycle Bin and if your missing files were in there, you would have gotten your errors even before running DF.
as for some background, what version of DF did you run? what size drive?, type:- SSD or HDD?, age of PC?
its a HDD, Samsung Spinpoint F3 (HD502HJ) 500Gb and its old a bit now. HDD's running time is 868 days so i would say, its about 5-6 years old
I didn't run any other software. I have the newest version, 2.19.982 (64bit).
during defragmentation, my pc went sleep once. i dont know if it can cause this problem.
edit: sorry, my bad. it's not missing, it has a different problem.
It says: "Bad image, xxx\dbghelp.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support."
it may be a bad area on the drive.
perhaps DF put that little too much stress on an already dodgy sector, and tipped it over the edge.
try running a CHKDSK from an elevated command prompt on the drive and see if any nasties show themselves.
it didnt find any error now.
i managed to find what did it do at first on the first boot today in the event viewer, maybe it will help.
C:\ and D:\ are the same HDD, just different partition. i did defragment on both.
Checking file system on C:
The type of the file system is NTFS.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
CHKDSK is verifying files (stage 1 of 3)...
The attribute of type 0x80 and instance tag 0x4 in file 0x3cd8
has allocated length of 0xc000 instead of 0xd000.
Deleting corrupt attribute record (128, "")
from file record segment 15576.
The attribute of type 0x80 and instance tag 0x4 in file 0x3cdd
has allocated length of 0x11000 instead of 0x10000.
from file record segment 15581.
The attribute of type 0x80 and instance tag 0x4 in file 0xf3a1
has allocated length of 0x1000 instead of 0x4000.
from file record segment 62369.
Attribute record of type 0x80 and instance tag 0x3 is cross linked
starting at 0x3b41 for possibly 0x1 clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x3
in file 0x2229e is already in use.
from file record segment 139934.
Cleaning up instance tags for file 0x26b96.
The attribute of type 0x80 and instance tag 0x1 in file 0x27230
has allocated length of 0x126000 instead of 0x127000.
from file record segment 160304.
198400 file records processed. File verification completed.
825 large file records processed. 0 bad file records processed. 2 EA records processed. 60 reparse records processed. CHKDSK is verifying indexes (stage 2 of 3)...
Unable to locate the file name attribute of index entry WD-20150517-1441.dmp
of index $I30 with parent 0x994b in file 0xaae0.
Deleting index entry WD-20150517-1441.dmp in index $I30 of file 39243.
Unable to locate the file name attribute of index entry WD5F26~1.DMP
Deleting index entry WD5F26~1.DMP in index $I30 of file 39243.
256190 index entries processed. Index verification completed.
0 unindexed files scanned. 0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 3)...
198400 file SDs/SIDs processed. Cleaning up 42 unused index entries from index $SII of file 0x9.
Cleaning up 42 unused index entries from index $SDH of file 0x9.
Cleaning up 42 unused security descriptors.
Security descriptor verification completed.
Inserting data attribute into file 15576.
Inserting data attribute into file 15581.
Inserting data attribute into file 62369.
Inserting data attribute into file 139934.
Inserting data attribute into file 160304.
28901 data files processed. CHKDSK is verifying Usn Journal...
33883664 USN bytes processed. Usn Journal verification completed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
68890623 KB total disk space.
45695140 KB in 150296 files.
86644 KB in 28897 indexes.
0 KB in bad sectors.
301175 KB in use by the system.
65536 KB occupied by the log file.
22807664 KB available on disk.
4096 bytes in each allocation unit.
17222655 total allocation units on disk.
5701916 allocation units available on disk.
Internal Info:
00 07 03 00 09 bc 02 00 92 41 05 00 00 00 00 00 .........A......
81 02 00 00 3c 00 00 00 00 00 00 00 00 00 00 00 ....<...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Windows has finished checking your disk.
Please wait while your computer restarts.
and
Checking file system on D:
that you continue.
starting at 0x639eb8b for possibly 0xa68 clusters.
in file 0x17d7 is already in use.
from file record segment 6103.
starting at 0x61bf437 for possibly 0x11476 clusters.
in file 0x17e0 is already in use.
from file record segment 6112.
starting at 0x3d3da30 for possibly 0x3231e clusters.
in file 0x17e1 is already in use.
from file record segment 6113.
starting at 0x5d6cc27 for possibly 0xdded clusters.
in file 0x17e7 is already in use.
from file record segment 6119.
Attribute record of type 0x80 and instance tag 0x0 is cross linked
starting at 0x5698ecf for possibly 0x1c98c clusters.
Some clusters occupied by attribute of type 0x80 and instance tag 0x0
in file 0x1803 is already in use.
Deleted corrupt attribute list entry
with type code 128 in file 6147.
Unable to locate attribute with instance tag 0x0 and segment
reference 0x6000000002c61. The expected attribute type is 0x80.
from file record segment 11361.
starting at 0x5184d28 for possibly 0x6d07a clusters.
in file 0x1b25 is already in use.
The attribute of type 0x80 and instance tag 0x0 in file 0x1b25
has allocated length of 0x505cb1000 instead of 0x46200d000.
with type code 128 in file 6949.
reference 0x3000000000d7a. The expected attribute type is 0x80.
from file record segment 3450.
reference 0xb000000000dcf. The expected attribute type is 0x80.
from file record segment 3535.
reference 0xa000000000de7. The expected attribute type is 0x80.
from file record segment 3559.
reference 0xb000000000df2. The expected attribute type is 0x80.
from file record segment 3570.
reference 0xb000000000e37. The expected attribute type is 0x80.
from file record segment 3639.
reference 0x3000000000e50. The expected attribute type is 0x80.
from file record segment 3664.
reference 0x3000000001243. The expected attribute type is 0x80.
from file record segment 4675.
reference 0x7000000001342. The expected attribute type is 0x80.
from file record segment 4930.
reference 0x2900000000134f. The expected attribute type is 0x80.
from file record segment 4943.
reference 0x1100000000139d. The expected attribute type is 0x80.
from file record segment 5021.
reference 0x13000000001491. The expected attribute type is 0x80.
from file record segment 5265.
reference 0xb0000000014c4. The expected attribute type is 0x80.
from file record segment 5316.
reference 0xc0000000014f9. The expected attribute type is 0x80.
from file record segment 5369.
reference 0xb0000000014fd. The expected attribute type is 0x80.
from file record segment 5373.
reference 0x10000000001584. The expected attribute type is 0x80.
from file record segment 5508.
reference 0x80000000017b0. The expected attribute type is 0x80.
from file record segment 6064.
reference 0x80000000017b1. The expected attribute type is 0x80.
from file record segment 6065.
reference 0x80000000017b2. The expected attribute type is 0x80.
from file record segment 6066.
reference 0x90000000017b3. The expected attribute type is 0x80.
from file record segment 6067.
reference 0x80000000017b4. The expected attribute type is 0x80.
from file record segment 6068.
reference 0x60000000017b5. The expected attribute type is 0x80.
from file record segment 6069.
reference 0x90000000017b8. The expected attribute type is 0x80.
from file record segment 6072.
reference 0x70000000017ba. The expected attribute type is 0x80.
from file record segment 6074.
reference 0x70000000017bb. The expected attribute type is 0x80.
from file record segment 6075.
reference 0x70000000017bc. The expected attribute type is 0x80.
from file record segment 6076.
reference 0x70000000017bd. The expected attribute type is 0x80.
from file record segment 6077.
reference 0x70000000017be. The expected attribute type is 0x80.
from file record segment 6078.
reference 0x70000000017ca. The expected attribute type is 0x80.
from file record segment 6090.
reference 0x70000000017cb. The expected attribute type is 0x80.
from file record segment 6091.
reference 0x60000000017cc. The expected attribute type is 0x80.
from file record segment 6092.
reference 0x60000000017cd. The expected attribute type is 0x80.
from file record segment 6093.
reference 0x70000000017ce. The expected attribute type is 0x80.
from file record segment 6094.
reference 0x70000000017cf. The expected attribute type is 0x80.
from file record segment 6095.
reference 0x70000000017d0. The expected attribute type is 0x80.
from file record segment 6096.
reference 0xa00000000185a. The expected attribute type is 0x80.
from file record segment 6234.
reference 0xa00000000185b. The expected attribute type is 0x80.
from file record segment 6235.
reference 0x800000000185c. The expected attribute type is 0x80.
from file record segment 6236.
reference 0x800000000185d. The expected attribute type is 0x80.
from file record segment 6237.
reference 0x900000000185e. The expected attribute type is 0x80.
from file record segment 6238.
reference 0x800000000185f. The expected attribute type is 0x80.
from file record segment 6239.
reference 0x9000000001860. The expected attribute type is 0x80.
from file record segment 6240.
reference 0x8000000001861. The expected attribute type is 0x80.
from file record segment 6241.
reference 0x9000000001862. The expected attribute type is 0x80.
from file record segment 6242.
reference 0x9000000001864. The expected attribute type is 0x80.
from file record segment 6244.
reference 0x8000000001865. The expected attribute type is 0x80.
from file record segment 6245.
reference 0x8000000001866. The expected attribute type is 0x80.
from file record segment 6246.
reference 0x8000000001868. The expected attribute type is 0x80.
from file record segment 6248.
reference 0x8000000001869. The expected attribute type is 0x80.
from file record segment 6249.
reference 0x900000000186a. The expected attribute type is 0x80.
from file record segment 6250.
reference 0xd00000000186d. The expected attribute type is 0x80.
from file record segment 6253.
reference 0x800000000186e. The expected attribute type is 0x80.
from file record segment 6254.
reference 0x800000000186f. The expected attribute type is 0x80.
from file record segment 6255.
reference 0x8000000001870. The expected attribute type is 0x80.
from file record segment 6256.
reference 0x8000000001871. The expected attribute type is 0x80.
from file record segment 6257.
reference 0x8000000001872. The expected attribute type is 0x80.
from file record segment 6258.
reference 0x8000000001873. The expected attribute type is 0x80.
from file record segment 6259.
reference 0x9000000001874. The expected attribute type is 0x80.
from file record segment 6260.
reference 0x8000000001875. The expected attribute type is 0x80.
from file record segment 6261.
reference 0x9000000001876. The expected attribute type is 0x80.
from file record segment 6262.
reference 0x8000000001879. The expected attribute type is 0x80.
from file record segment 6265.
reference 0xd00000000187b. The expected attribute type is 0x80.
from file record segment 6267.
reference 0x800000000187d. The expected attribute type is 0x80.
from file record segment 6269.
reference 0x8000000001883. The expected attribute type is 0x80.
from file record segment 6275.
reference 0x9000000001885. The expected attribute type is 0x80.
from file record segment 6277.
reference 0x8000000001887. The expected attribute type is 0x80.
from file record segment 6279.
reference 0x8000000001888. The expected attribute type is 0x80.
from file record segment 6280.
reference 0x1300000000188c. The expected attribute type is 0x80.
from file record segment 6284.
reference 0xb00000000188f. The expected attribute type is 0x80.
fro
Wow, quite a few errors then, on both partitions.
I'd be doing that CHKSDSK for the next few days/weeks to see if more pop up or just to check things settle down.
With the drive being ~5 years old, personally I'd seriously consider doing a pre-emptive strike and replace it before it forces your hand.
I'd certainly be doing my backups more frequently.
As long as those errors don't get in the way, I'd be imaging/cloning that drive at my earliest opportunity.
I would check disk surface too. chkdsk /r
