Many people often report having problems with MSVBVM60.DLL or other Visual Basic related error messages. Over time there is generally one simple solution. Simply downloading the Visual Basic 6 Runtimes will resolve many of these errors.
You may wish to try and download the Visual Basic 6 Runtimes as this can often fix many problems.
Note: Some computers may require a reboot after installing the runtimes.
If this does not fix your problem, please make a New Topic describing the error you are having. You may also click the following image to start a new topic:
Download: Microsoft Visual Basic 6 Runtimes
