I heard that it doesn't clean SSD's right. Male it work on those.
No that is not the case, I believe whomever told you that was attemping to inform you that you should not use Wipe Free Space nor The Disk Wiper Utility on the SSD
Nor secure file deletion, but the Cleaner and Registry sections are fine.
