When 'software updater' runs it tries to download 32-bit installer for this program not 64-bit installer. Maybe other progs as well?
Hope this helps.
Hope this helps.
Hi @funduckit Thanks for bringing this to our attention; it sounds like something is amiss because CCleaner should be installing updates for the same version (32/64-bit) of the program that is installed, rather than it attempting to update a 64-bit version of Notepad++ with a 32-bit installer.
I will be testing this on our lab computer(s) to verify if I can replicate the issue and will report this to our Software Updater team so they can correct the problem.
I'll follow-up with you on this again as soon as possible and meanwhile, please don't hesitate to reply if anything else is needed.
Hi @funduckit I can confirm this has been resolved so as of now, Software Updater will no longer attempt to install the 32-bit version of Notepad++.
Thanks again for making us aware of this issue as we greatly appreciate that!
