Hi,
firstly I'd like to thank you for a great soft
secondly - I'm kinda concerned about - very often I see in the bottom textbox with path of currently processed file a file with size < 100kB (e.g. 21kB) hanging there for like 0.5-1 seconds.
I think files so small should be processed so quickly I shouldn't be able to even see the path properly...I don't know, I just think so, maybe it's normal?
I rebooted to safe mode and the result is the same
I have windows 7 64bit
If it should really be faster ... is there a way how to speed it up?
Thank you (and if you need more info I'd gladly provide)
Edit 1:
I just started Defraggler in command-line in debug3 mode... I was unable to use /large (df.exe D: /debug /large) but that didn't really work, otherwise it should be same as GUI
but so far it seems to be running MUCH faster, the HDD activity increased significantly... in GUI version although it ran through large number of small files it ran slowly and HDD activity almost none and after 8 hours (provided large files were moved to back already) it defragmented only maybe a little more than 100MB out of 440GB disc
Edit 2:
So it might have been due to /large, I just figured out how to use it...meh
