Greetings,
So I deleted a "useless" registry startup entry-so I thought after diligent research.
The dreaded popup message " IgfxTray.exe can't be found error message" now appears on start-up. I never adjust my Intel graphics settings on this laptop. It's purely a number crunching spreadsheet laptop. So i deleted it instead of using "disable."
And no it is not a virus version.
And no I didn't save a copy because I've used Ccleaner for years and never deleted a registry entry that I didn't need.
So why am I here?
Well I read that is it possible to find and restore deleted Ccleaner registry files manually.
Something about .inf files stored in the Ccleaner documents files.
However, I cannot find where Ccleaner has stored the deleted registry files on my computer. They do not appear in "my documents" folder.
I am always logged in as Admin.
I can see the entries when I use Autorun; but cannot seem to restore them this way.
Thanks for any help.
SIncerely,
C.
