Hi Guys,
{XP Pro, SP2; CCleaner v2.03.532}
First I must say that I did not install any new Software since update to the latest CCleaner.
Recently I visited Event Viewer (System part) and found a set of SideBySide Error events (see below in P.S.).
Interestingly enough when analysing the log I discovered that it may occur only once in a current session (from current computer Restart to the next one).
It is worth to make a note that I don?t see any ill effects. The computer is working fine.
But there are no other Error Events other than mentioned sets.
To make the story short?:
According to descriptions found "out there" the error caused by conflicts, where C++ Redistribution RunTime Libray involved.
MS advises to reinstall it. Done?. to no avail.
I was monitoring every program I start every button I click to find out the ?mystery moment" of SideBySide error set appears.
And I found it:
The very first start of CCleaner in current session! 100%
Just first run ? GUI appears ? SideBySide errors are in the System Event log.
Any subsequent call and run of CCleaner will not produce those errors any more within a current session.
Needless to say that I did check all (well?practically), lets say, a lot of other programs when monitoring System Event Viewer.
Am I alone here with this phenomenon?
Thanks in advance for any information
My regards
P.S.
From System Evants Error Log:
7/12/2007 7:52:15 PM SideBySide Error None 59 N/A XP-PRO-BOX Generate Activation Context failed for C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.163_x-ww_39049d00\MFC80U.DLL. Reference error message: The operation completed successfully.
7/12/2007 7:52:15 PM SideBySide Error None 59 N/A XP-PRO-BOX Resolve Partial Assembly failed for Microsoft.VC80.MFCLOC. Reference error message: The referenced assembly is not installed on your system.
7/12/2007 7:52:15 PM SideBySide Error None 32 N/A XP-PRO-BOX Dependent Assembly Microsoft.VC80.MFCLOC could not be found and Last Error was The referenced assembly is not installed on your system.
