My license for Nod32 is running out and I don't want to spend another load of money to get another license for it. Should I switch to Avast? Or should I just buy another license for Nod32?
It's personal choice. If you have something that works really well for you, you can regret making a change and finding out that the new software doesn't play well with your system.
Not an easy decision really.
I can tell you it's not easy. I think I'm going to switch though. I don't want to keep paying every 6 months to renew my license. Plus Avast seems to be an excellent AV from all the great reviews I've heard about it. Well, off to download Avast now!
Plus, Nod32 seems to be using a lot of memory. About 50 megs when it's running normally. Even though memory usage isn't a problem for me, I still like problems that don't use that much memory. Avast seems to be perfect.
Whoa I just installed Avast and restarted my PC a few minutes ago, and bootup time and the time it takes for everything to fully load is a lot faster now. I'm not sure, but my internet speed seems faster too. This is a + for me.
Most definitely switch to avast. Avast is very light weight and is amazing compared to other free AVs.
Amazingly enough, I agree with Comper6. Avast free version is excellent.
Will close this thread now as you have posted your experiences of Avast in this other thread
