Shellextension xnView stays after registry cleanup
Hello,
i want to report that the shellextension from xnView stays in the rightclick contextmenu of a folder ("view with xnview").
The guys doesnt cleanup the shellextension if it was enabled.
Just a suggestion to add to ccleaner.
What is xnView, what program does it belong to? Do you still run that program? Is it a system program?
1. Start CCleaner.
2. Click Tools > Startup > Context Menu
If CCleaner doesn't display it or can't remove it you may need to try NirSoft ShellExView or ShellMenuView.
