Several Suggestions for Recuva
  1. Organize files better (i.e. improve Searching, allow Sorting by Date Deleted, File Type, Recovery Chance/Status, etc.)
  2. Option for not finding files deleted by CCleaner
I dont think there's a way for Recuva to know that CCleaner deleted a file specifically.
OK, then I think that should be part of the option, if it's doable. It's just an idea, after all.
Although it could be improved, you can (in Advanced mode) already sort by column heading or File/Path, or a combination of both.
There's also the option of not showing Securely Overwritten Files in Options/Actions, but I don't think it's that accurate.
