- Replace Windows Disk Cleanup
- Allow Cleaning only of Analyzed Files to save time often spent Cleaning sections with nothing in them to remove - If the User wants to Clean Empty Space, that's what the Wipe Free Space Option is for.
Reason for editing: I didn't know you could switch back to Detailed View. Thanks, Winapp2.ini!
1. If you double click on an option, you can see detailed analysis info, then you get an arrow in the left hand corner to go back to summary results
2. CCleaner does handle a lot of what disk clean up does
3. Good idea!
+1
Defraggler can replace Windows defraggler, so why not let CCleaner replace Disk Cleanup?
Why be redundant?
I'd love to make CCleaner default cleaner!
