Setting return to default
I use Microsoft Office 2003 Pro, I have recently D/L?ed CCleaner and developed a small problem.
Can any of you tell me which box I should uncheck so CC will not change my settings back to the default in Word?
Example: Under General, listed documents change from 9 to 4, under spelling & grammar ? Ignore words in all UPPERCASE, words with numbers keep rechecking so they slip by the spell checker, and in my standard toolbar, the Hide/Show button keeps going back to Hide.
Hope you can help..
Thanks
Esmie
Cleaner->Applications->Applications: Uncheck Office 2003
Now CCleaner will no longer mess with your settings.
Thank You.. :D
