Securely overright checked (and Highlighted) fails
Version 1.29.429
After Scan, with view set to list, having all files checked (top box checked), can no longer choose to "securely overwrite checked files" when right clicking on any file name, the option is grayed out.
Also can no longer select all files (Select top, Shift hold, Select bottom) and right click to "securely overwrite selected files", the option is grayed out. In the later case there is a change in the meaning of select all is getting interperated as "select all folders".
Hi Tom, and welcome to Piriform.
Have a read here, the devs are aware of the problem:
http://forum.piriform.com/index.php?showtopic=23366
