Seamonkey is not the same after CCleaner sweep
Hello,
Before reporting, I searched the topic but could not find any problem. So I am reporting one:
I have Pentium 4 2.4 GHz 768 MB RAM XP SP3
CCleaner 2.14.763
I use Mozilla Seamonkey mail and browser, version 2.0.3 English. Since I used CCleaner few days ago, some web pages--including gmail--are not loading properly on Seamonkey. Mozilla Firefox and Explorer are functioning just fine. I used to have the same problem with earlier versions of Seamonkey, but after re installing it, it would be OK. This time, reinstall did not work. Or I would run a copy of Mozilla (that came after Netscape died an before Firefox was born); it would restore things back to normal. Having tried all kinds of "old wives medicines" I am still at loss and desperate.
I hope you have a solution for me already. Here is a link to try: www.ogu.edu.tr
Here are the screen shots: samples
Things were fine before ccleaning.
Sincerely yours,
Hasan
Please upgrade CCleaner - latest is 2.29.
Did you use the Registry cleaner ?
Yeah 1.14 is more than 5 years old now. CCleaner has come a long way since then, including updates to cleaning the browsers.
CCleaner 2.14.763 is not that old (it is not 1.14)
I did not use registry cleaner
Yes, but you should upgrade. There's one new version each month or so. This means 2.14 is 15 months old...
