SD card recovery: Invalid Drive Size
Hi there!
I'm trying to recover an SD card, and when I try to run Recuva, it immediately pops up the error "Invalid Drive Size". I tried doing the deep scan, and got the same result. I'm not sure what exactly the problem is with the card - I had it in my phone, working fine, then all of a sudden it just stopped working.
I'd appreciate any help.
Has the file system been changed at some time, or is the card still as it was when you got it, before it got messed up? scan your drive with another recovery software and see if the data is recoverable by previewing your files.
My oh my, what a toxic IP address you have....
