Dear fellow members i have just recently downloaded because for some reason i couldnt get the disc defragmenter to work on windows vista. I have set a schedule to run monthly commencing 22.12.08 but what i wanted to check is, for example when i used to run this automatically on vista, you could go into the schedule and it would show you the last time the programme was run.
Can you do this with this programme ?, surely you ust be able to because otherwise how do you trust it is working ?
Any help would be much appreciated
thanks
