Hi,
I tried to scan my HD with Recuva but the scan stuck on 69%.
I even tried to start it again, but it's again stuck on 69%.
What can I do?
Thank you.
Ohad.
Hi,
What can I do?
Thank you.
Ohad.
How long did you leave it running?
9 Hours..
Could be stalling on bad clusters, try running a check disk.
Either go to the tools pane of the drive properties and select error check (scan and fix all issues) or run chkdsk /r and reboot the computer. This process can take a long time, so I suggest running it overnight. Your computer will boot normally after its finished
