I have a site where I want CC Browser to save the login (ID and Password). It says it saved them, but it can't open the site. The URL is long, and it looks like CC Browser truncates it, so it won't open. How can I fix this?
Some websites will not allow 'Autofill' of passwords, and sometimes usernames, it's a security measure by the website itself.
You can save the login details in your browser or password manager; but the website itself will insist that you have to type it in.
Banks, and anywhere else that may may mean spending money, should do this to keep you safe from fraudsters.
Can you automatically log onto the same site from a different browser?
I use Roboform's password manager for Firefox and Chrome, and have no problems with either of them. But Roboform doesn't recognize CC Browser, so I am trying to use CC Browser's password manager. That's where my problem is.
I have found that if I save a shortcut to the site, CC Browser will open the site, but it won't automatically enter my saved ID and password. However, if I enter my ID, it will automatically enter the password, and I can get into the site. So I can deal with that.
BUT, I have 2 logins for this site, and CC Browser will not let me make a shortcut for the second login. It just ignores what I enter. However, If I use the original shortcut, it will open the site, but when I enter the 2nd ID, it wants to use the same password as for the 1st ID. When I try to change the password to the 2nd ID, it want to change the 1st ID. Is there anyway around this? Otherwise, I will have to use either Firefox or Chrome when I need to use the second login.
I like the speed of CC Browser and I would like to be able to use it for everything, so I hope there is a way to do this.
I don't think you can get around the two different login thing.
At another forum I have two logins, one as a moderator and one as a regular member.
But of course my browser (I normaly use Firefox but it's the same for any browser) has no way of knowing which one I want to log in as at any time, only I can decide that.
I just let it fill in the name password for the moderator account, and if I want to use the regular account then I enter it manually.
The browser, or password manager, can save both usernames/passwords but it can't know which one you want to use at any given time.
Most will simply use the latest one of the two that was saved.
The problem for me is that this is a bank in which I have 2 different accounts. So the first thing I enter when trying to login is which account. That's where the browser gets confused. Since I have saved one of the account nos and password, when I enter the other account no and password, the browser somehow thinks I just want to change the password for the first account. I know this is because the URL is the same since it is to the same bank. Somehow it doesn't see that the account numbers are different.
I guess it can't be fixed unless somehow it could identify that one URL can have multiple logins. I wish I could get Roboform to work with CC Browser. That would take care of all the problems.
But thanks for the explanation.
As said above it's unusual these days for a banking site to let you autofill a password anyway.
It's a security risk, if you have it saved on phone/laptop and that device gets lost or stolen then whoever gets hold of it can automatically log into your bank account and take your money.
You are safer never to save any password for a banking or other financial site.
You are right abut the risk, so I have never(!) saved any passwords for any site that I don't want to risk - especially banking!?
With more playing around, I have a reasonably easy procedure for my problem site with CC Browser. Sort of complicated but it works and is easier than doing it manually.
Thanks!
Ccleaner Browser has stopped saving passwords/IDs. Chrome saves the user ID and password just fine for a particular site, Ccleaner Browser will not save on any site - it's not a website issue. It is a Ccleaner Browser issue.
Also, is there a way to sync passwords with Chrome Browser?
Thanks for your help
CCleaner Browser does not include any syncing functionality.
If you visit: secure://settings/passwords in CCleaner Browser, is "Offer to save passwords" enabled? Are the sites you're trying to save passwords for in the 'Never Save' section, and if so, does this get resolved if you click the "X" to move them out of that section?
