Version 7.4.1172.0
The guide in FAQ doesn’t seem to relate to this version.
I have tried following the instructions but am getting nowhere.
I’m fed up with having to obtain a text message before I can sign in to either Gmail and AOL to name but two.
Healthcheck: run a scan (not clean) and then in the right pane will appear a button called cookies settings.
Custom clean in the right pane (before or after a scan it doesn’t matter) a butron called configure leads to cookies.
It’s no longer pick cookies but instead domain whitelisting (enter or import a domain) when it uograded from ccleaner 6 (if it did it correctly some have not experienced this) your cookies to keep should have imported (or consumed actually) your cookies to keep in cc 6
it might not be an issue with ccleaner’s not saving cookies but rather the way that the websites are set up. i experience a lot of times where i am automatically signed out of a website, after a period of time (which can be very annoying).
are you able to stay logged in to this forum? if so, that shows that it is not a problem with ccleaner’s failure to save cookies but rather the way that the websites are set up.
