Running CCleaner
Apologies if this has been asked before, I did a search but couldn't find anything that matched.
Everytime I press the Analyze button on CCleaner, I get told there is XXX amount of rubbish to be removed but when I press the Run Cleaner button, only a small part of XXX is removed.
Any help or advice would be appreciated.
In options- advanced there is a tickbox for only delete Windows temp files older than 24hours.
Perhaps that may be it.
If not are there certain files that are being left each time?
I once had a dream that a really kind lady from Huddersfield came to my rescue when I had a problem.
After unticking the box you mentioned, it worked, everything was cleaned out, thanks for the reply, much appreciated. You're a star.
Mike
