I am running 3.07 on a Windows XP SP3 PC, but every time I try to install 3.15, I just get a cmd box on the screen for a second, then it disappears and no install takes place. I have tried many times, always with the same result. I'm running 3.15 on other PCs, all XP SP3. I'm stumped. Appreciate any help.
Make sure you choose 'download' and not 'run' from the download box when you are on the website you are downloading it from. Then install it on your machine.
Are your antivirus/malware apps up to date and all scans clean?
