Revert Delete Entry
Hello,
I wanted to remove a program with CCleaner. I selected the program and moved my mouse rightwards to find that button of need. I saw the button 'Delete' and it was clicked in a moment. But then I realised -once again- that it is not actually the button I needed. It didn't delete the program, moreover it blocked my only means to delete the program. Now I'm wondering how to remove/delete my program finally. It's not in the list anymore, and I don't want it to lurk deep in my computer.
I believe that there is a UI design issue here. It happened many times and it keeps happening. In your documentation it says an 'advanced user' action but it is too reachable and not safe (it doesn't ask for any confirmation).
So I suggest a UI refactoring and seek help to remove that program (It was a driver, I can't find in program files directory or with name search)
Thanks.
You can either use a System Restore Point to undo the change - if you have a more recent one.
-or-
Look in the folder where the program was installed, if it has an uninstall .exe file in it run that to uninstall the program.
-or-
Reinstall the program which will make the uninstall available again.
Thanks for the help. I think I will leave that program lost in deep.
These are quite expensive methods (time-wise) to revert a one-click action, there is definitely a UI design issue here.
