Does the restore point you created show up in System Restore?
If Not then you have a problem with System restore.
If it does then you have a problem with CC.
Ima neubie: how would you describe a 'restore point?' I'm having a silly problem keeping the scores on 'games' . When I get a nice high score, run CCLEANER , I lose them. But back to "restore point' . what is that? thanks.
Wanda
You really need to start a separate topic because this topic is focussed upon REMOVING restore points,
whilst your needs are the opposite - you are wanting to use them.
By using this particular topic you may get and use information that will not help you but would destroy your restore points.
Also please note that there are far better ways to avoid losing scores than to use system restore.
I suggest you start a post with a title like "CCleaner destroys my scores on the game 'XYZ'".
You may even get step by step guidance from a fellow games enthusiast.
It would be better to post in the CCleaner Discussions forum.
